Cables and connector configuration for FSP-FC250 (2967-FSP-FC250-ND)
------Question for FSP-FC250 Please Put your question below------
Hello, This is my first time posting on TechForum, so please excuse any formatting errors.
I am considering purchasing the FSP-FC250, an FSP server-grade CRPS redundant power supply cage (PDB), for a custom server build.
Product page: https://www.digikey.jp/en/products/detail/fsp-technology-inc/FSP-FC250/16164278
Could you please help me clarify the following two questions regarding this product?
  1. Are the modular output cables included with this product by default? (I came across a past post on the English forum mentioning that cables are included, but I would like to verify if this is still the current specification.)
  2. If the cables are included, could you provide the specific cable and connector configurations (such as the number of pins, count of 24-pin ATX, 8-pin EPS, SATA connectors, etc.)?
I plan to use a “Supermicro X11DAi-N” motherboard for my build, which requires a standard 24-pin ATX power connector and 8-pin EPS connectors for the CPUs.
I would like to know if this power supply can connect to and power this motherboard directly out of the box, or if I will need separate adapters or proprietary cables.
Thank you in advance for your assistance.
If a product manager confirmed it, it is valid:
However, I do not know the configuration of the cable set. I am assuming that they are probably one to one where the ports on the supply match the ports on the cable and the other end matches the same type of connector. I can reach out to the manufacturer to see if we can get some kind of specification sheet or detail on the cable set.
Thank you for your reply.
I appreciate you checking with the manufacturer to get the official specification sheet. Since I want to avoid any compatibility issues or damage to the equipment, I would feel much more comfortable waiting for the confirmed details.
Please let me know once you receive the specifications or any updates.
Best regards.
The manufacturer provided five documents that contain details about the cable. They informed me that they do not want this publicly facing, so I will send you a direct message using our Forum system.
Thank you for contacting the manufacturer and obtaining the documents.
I look forward to receiving your direct message.
Thank you for your assistance.
