What is the casing material of the Eaton KW-5R5C105-R supercapacitor? Is there a material declaration or technical document that lists all materials present in the part, including its internal components?
Thank you!
Thank you!
@lamia Welcome to DigiKey’s TechForum!
The case material is alloy steel, and you will have to ask MDS(Material Declaration Sheet) from Environmental Information Request.
Best regards,
