CASS-18U-6-NHX data sheet
------Question for CASS-18U-6-NHX Please Put your question below------ please provide data sheet for CASS-18U-6-NHX. I have check the data sheet of CASS-18U-6-NHX from your portal, but i could not find CASS-18U-6-NHX from the data sheet. please help
Hello @viki
This is the only available datasheet on the manufactures website.
The datasheet may not list every part number because the product supports many possible combinations. To avoid repetitive chart, OMEGA does not print all configurations. Your part number follows the same model‑number format, so it is still a valid configuration.
You can check the specs here, Thermocouple Probes with Standard Size Ceramic Connectors
