It for a car transmission controler. The one I have is made to control a newer trans .
Do you have a part number off of the old one?
There is no ale one.
Hello @Karl_1696,
Understand you have a 0 to 12 VDC PWM signal. You want to convert this to a 0 to -12 VDC referenced binary (on off) signal.
Assumptions
The new signal is on when the input PWM is at some arbitrary threshold e.g., 50 or 75%.
The output is driving a solenoid.
To my knowledge, there are no readily available modules. However, it could be assembled using a microcontroller or op-amp based circuitry plus supporting components such as a relay.
Sincerely,
Aaron
