Changing sample rate on BQ28Z620EVM
The data sheet for BQ28Z620EVM says that the current() function updates once per second with the current going through the chip. Is there a way to change that sample rate? I’d like something closer to 10 per second if possible.
Thanks!
Ari
Greetings,
Assuming you’re referring to section 14.1 of the reference manual for BQ28Z620EVM, I read that to indicate that it runs on a fixed timetable, and wouldn’t likely be user adjustable.
