------Question for MA9-5N Please Put your question below------
What connector terminates this antenna? The spec sheet simply says “N-type”. Is it N-female? or N-male? And strangely a NMO connector is also listed adding to confusion.
Hello @lawresh,
This whip antenna has an N-male connection. Visually verified on DigiKey and OEM supplied pictures.
The extra central shielding makes N-connector harder to identify. However, we can see the central pin.
Don’t know what to say about the NMO connection, not the same thing.
Note that the MA9-5N is the only TE antenna rated for 901-941 frequency band.
Sincerely,
Aaron
