For VPG Foil Resistors – Y14880R01000B9R, if you have any doubts about why the notch dimensions look different from what is shown in the datasheet, please refer to the manufacturer’s explanation below:
The image in the datasheet is only a general reference.
The notch/slot design of the CSM3637 resistor can vary depending on customer‑specific requirements, which is why the dimensions figure in the data sheet the slots depth is not specified.
The part shown in the images above is correct, and any differences in the notch or slot appearance can be safely ignored.
Applicable Part Numbers
| 804-Y14750R10000B9RTR-ND,804-Y14750R10000B9RCT-ND,804-Y14750R10000B9RDKR-ND | Y14750R10000B9R |
| 804-Y14750R03000E9W-ND | Y14750R03000E9W |
| 804-1177-ND | Y14720R02500E9W |
| 804-Y14750R10000F9W-ND | Y14750R10000F9W |
| 804-Y14880R04000F89RTR-ND | Y14880R04000F89R |
| 804-Y14880R01000F80WTR-ND | Y14880R01000F80W |
| 804-Y14880R02200F80RTR-ND | Y14880R02200F80R |
| 804-Y14880R05000F89RTR-ND | Y14880R05000F89R |
| 804-Y14880R02200F89RTR-ND | Y14880R02200F89R |
| 804-Y14880R02000F89RTR-ND | Y14880R02000F89R |
| 804-Y14880R20000F89RTR-ND | Y14880R20000F89R |
| 804-Y14880R03300F89RTR-ND | Y14880R03300F89R |
| 804-Y14880R04990D80WTR-ND | Y14880R04990D80W |
| 804-Y14880R01000D89RTR-ND | Y14880R01000D89R |
| 804-Y14880R00100D89RTR-ND | Y14880R00100D89R |
| 804-Y14880R02000B89RTR-ND | Y14880R02000B89R |
| 804-Y14880R02000B80RTR-ND | Y14880R02000B80R |
| 804-Y14880R10000B89RTR-ND | Y14880R10000B89R |
| 804-Y14880R05000B80RTR-ND | Y14880R05000B80R |
| 804-Y14880R20000B89WTR-ND | Y14880R20000B89W |
| 804-Y14880R20000B80RTR-ND | Y14880R20000B80R |
| 804-Y14880R20000B89RTR-ND | Y14880R20000B89R |
| 804-Y14880R20000B99RTR-ND | Y14880R20000B99R |
| 804-Y14880R10000B89WTR-ND | Y14880R10000B89W |
| 804-Y14880R05000B89RTR-ND | Y14880R05000B89R |
| 804-Y14880R02500B89RTR-ND | Y14880R02500B89R |
| Y14720R01000F0R-ND | Y14720R01000F0R |
| Y14720R04000F0R-ND | Y14720R04000F0R |
| Y14720R10000F0R-ND | Y14720R10000F0R |
| Y14720R05000E0R-ND | Y14720R05000E0R |
| Y14720R10000E9R-ND | Y14720R10000E9R |
| 804-Y14880R02520B9W-ND | Y14880R02520B9W |
| 804-Y14710R00800D9W-ND | Y14710R00800D9W |
| Y14750R02000F9R-ND | Y14750R02000F9R |
| Y14750R10000F9R-ND | Y14750R10000F9R |
| Y14750R20000F9R-ND | Y14750R20000F9R |
| 804-Y14710R02500B9W-ND | Y14710R02500B9W |
| 804-Y14880R01500F9W-ND | Y14880R01500F9W |
| 804-Y14880R03000F9W-ND | Y14880R03000F9W |
| 804-Y14880R03300F0W-ND | Y14880R03300F0W |
| 804-Y14880R02200F0W-ND | Y14880R02200F0W |
| 804-Y14880R01500F0W-ND | Y14880R01500F0W |
| 804-Y14710R04000F9W-ND | Y14710R04000F9W |
| 804-Y14710R02000F9W-ND | Y14710R02000F9W |
| 804-Y14880R00300D9W-ND | Y14880R00300D9W |
| 804-Y14880R03000D9W-ND | Y14880R03000D9W |
| 804-Y14880R01500D0W-ND | Y14880R01500D0W |
| Y14750R02000B9R-ND | Y14750R02000B9R |
| Y14750R02500B9R-ND | Y14750R02500B9R |
| Y14750R04000B9R-ND | Y14750R04000B9R |
| Y14750R05000B9R-ND | Y14750R05000B9R |
| Y14750R20000B9R-ND | Y14750R20000B9R |
| Y14750R02000B0R-ND | Y14750R02000B0R |
| Y14750R05000B0R-ND | Y14750R05000B0R |
| Y14750R20000B9W-ND | Y14750R20000B9W |
| 804-Y14880R02000F0R-ND | Y14880R02000F0R |
| 804-Y14880R03300F0R-ND | Y14880R03300F0R |
| 804-Y14880R00400F9R-ND | Y14880R00400F9R |
| 804-Y14880R02200F0R-ND | Y14880R02200F0R |
| 804-Y14880R00500F0R-ND | Y14880R00500F0R |
| 804-Y14880R03330F0R-ND | Y14880R03330F0R |
| 804-Y14880R03300F9R-ND | Y14880R03300F9R |
| 804-Y14880R05000F0R-ND | Y14880R05000F0R |
| 804-Y14880R02200F9R-ND | Y14880R02200F9R |
| 804-Y14880R03400F0R-ND | Y14880R03400F0R |
| 804-Y14880R10000F0R-ND | Y14880R10000F0R |
| 804-Y14880R04990F0R-ND | Y14880R04990F0R |
| 804-Y14750R04700F0W-ND | Y14750R04700F0W |
| 804-Y14750R05600F9W-ND | Y14750R05600F9W |
| 804-Y14750R07500F9W-ND | Y14750R07500F9W |
| 804-Y14750R04000F9W-ND | Y14750R04000F9W |
| 804-Y14750R03300F9W-ND | Y14750R03300F9W |
| 804-Y14750R02500F9W-ND | Y14750R02500F9W |
| 804-Y14750R06000F9W-ND | Y14750R06000F9W |
| 804-Y14750R02000F0W-ND | Y14750R02000F0W |
| 804-Y14750R03500F9W-ND | Y14750R03500F9W |
| 804-Y14750R20000F0W-ND | Y14750R20000F0W |
| 804-Y14750R20000F9W-ND | Y14750R20000F9W |
| 804-Y14750R05000F0W-ND | Y14750R05000F0W |
| 804-Y14750R02000F9W-ND | Y14750R02000F9W |
| 804-Y14720R01000F0W-ND | Y14720R01000F0W |
| 804-Y14880R00680D0R-ND | Y14880R00680D0R |
| 804-Y14880R03330D0R-ND | Y14880R03330D0R |
| 804-Y14880R01200D9R-ND | Y14880R01200D9R |
| 804-Y14880R00200D9R-ND | Y14880R00200D9R |
| 804-Y14880R02400D9R-ND | Y14880R02400D9R |
| 804-Y14880R00330D0R-ND | Y14880R00330D0R |
| 804-Y14880R00240D9R-ND | Y14880R00240D9R |
| 804-Y14880R02500D0R-ND | Y14880R02500D0R |
| 804-Y14880R02500D9R-ND | Y14880R02500D9R |
| 804-Y14720R01500D9W-ND | Y14720R01500D9W |
| 804-Y14750R10000D9W-ND | Y14750R10000D9W |
| 804-Y14750R20000D0W-ND | Y14750R20000D0W |
| 804-Y14750R02500D0W-ND | Y14750R02500D0W |
| 804-Y14750R02500D9W-ND | Y14750R02500D9W |
| 804-Y14750R20000D9W-ND | Y14750R20000D9W |
| 804-Y14750R05000D9W-ND | Y14750R05000D9W |
| Y14750R05000F9W-ND | Y14750R05000F9W |
| 804-Y14880R03000B0R-ND | Y14880R03000B0R |
| 804-Y14880R02520B0R-ND | Y14880R02520B0R |
| 804-Y14880R06000B9R-ND | Y14880R06000B9R |
| 804-Y14880R07500B0R-ND | Y14880R07500B0R |
| 804-Y14880R02520B9R-ND | Y14880R02520B9R |
| 804-Y14880R08330B9R-ND | Y14880R08330B9R |
| Y14720R04000F0W-ND | Y14720R04000F0W |
| Y14720R04000F9W-ND | Y14720R04000F9W |
| 804-Y14750R20000C9W-ND | Y14750R20000C9W |
| 804-Y14750R20000C0W-ND | Y14750R20000C0W |
| 804-Y14750R02000C9W-ND | Y14750R02000C9W |
| 804-Y14750R20000E0W-ND | Y14750R20000E0W |
| 804-Y14750R02000E9W-ND | Y14750R02000E9W |
| 804-Y14750R20000E9W-ND | Y14750R20000E9W |
| 804-Y14750R10000E9W-ND | Y14750R10000E9W |
| 804-Y14750R10000B9W-ND | Y14750R10000B9W |
| 804-Y14750R02500B0W-ND | Y14750R02500B0W |
| 804-Y14750R02520B0W-ND | Y14750R02520B0W |
| 804-Y14750R08330B9W-ND | Y14750R08330B9W |
| 804-Y14750R12500B9W-ND | Y14750R12500B9W |
| 804-Y14750R05000B9W-ND | Y14750R05000B9W |
| 804-Y14750R06600B9W-ND | Y14750R06600B9W |
| 804-Y14750R07500B9W-ND | Y14750R07500B9W |
| 804-Y14750R10000B0W-ND | Y14750R10000B0W |
| 804-Y14750R05000B0W-ND | Y14750R05000B0W |
| 804-Y14750R20000B0W-ND | Y14750R20000B0W |
| 804-Y14750R14300B9W-ND | Y14750R14300B9W |
| 804-Y14750R03000B0W-ND | Y14750R03000B0W |
| 804-Y14710R01000D9R-ND | Y14710R01000D9R |
| 804-Y14710R00200D9R-ND | Y14710R00200D9R |
| Y14720R02500E0W-ND | Y14720R02500E0W |
| 804-Y14710R02000F9R-ND | Y14710R02000F9R |
| 804-Y14710R07500F9R-ND | Y14710R07500F9R |
| 804-Y14710R00500F9R-ND | Y14710R00500F9R |
| 804-Y14710R10000F9R-ND | Y14710R10000F9R |
| 804-Y14710R05000F9R-ND | Y14710R05000F9R |
| 804-Y14710R03000F9R-ND | Y14710R03000F9R |
| 804-Y14710R04000F9R-ND | Y14710R04000F9R |
| Y14750R02000B0W-ND | Y14750R02000B0W |
| Y14750R02000B9W-ND | Y14750R02000B9W |
| 804-Y14710R00500D9R-ND | Y14710R00500D9R |
| Y1488-.005CTR-ND,Y1488-.005CCT-ND,Y1488-.005CDKR-ND | Y14880R00500F9R |
| 804-Y14710R07500B9R-ND | Y14710R07500B9R |
| 804-Y14710R09500B9R-ND | Y14710R09500B9R |
| 804-Y14710R03000B9R-ND | Y14710R03000B9R |
| 804-Y14710R01000B9R-ND | Y14710R01000B9R |
| 804-Y14750R04000F9R-ND | Y14750R04000F9R |
| 804-Y14750R10000F0R-ND | Y14750R10000F0R |
| 804-Y14750R04990F0R-ND | Y14750R04990F0R |
| 804-Y14750R05000F9R-ND | Y14750R05000F9R |
| 804-Y14750R07500F9R-ND | Y14750R07500F9R |
| 804-Y14750R05000F0R-ND | Y14750R05000F0R |
| 804-Y14750R03500F9R-ND | Y14750R03500F9R |
| 804-Y14750R04000F0R-ND | Y14750R04000F0R |
| 804-Y14750R03000F9R-ND | Y14750R03000F9R |
| 804-Y14750R10000D9R-ND | Y14750R10000D9R |
| 804-Y14750R03000D9R-ND | Y14750R03000D9R |
| 804-Y14750R05000D0R-ND | Y14750R05000D0R |
| 804-Y14750R02500D9R-ND | Y14750R02500D9R |
| 804-Y14750R05000D9R-ND | Y14750R05000D9R |
| 804-Y14750R10000D0R-ND | Y14750R10000D0R |
| 804-Y14750R02500D0R-ND | Y14750R02500D0R |
| 804-Y14750R02000C9R-ND | Y14750R02000C9R |
| 804-Y14750R02500C9R-ND | Y14750R02500C9R |
| 804-Y14750R03000C9R-ND | Y14750R03000C9R |
| 804-Y14750R03000E9R-ND | Y14750R03000E9R |
| 804-Y14750R10000E9R-ND | Y14750R10000E9R |
| 804-Y14750R02520B0R-ND | Y14750R02520B0R |
| 804-Y14750R08000B9R-ND | Y14750R08000B9R |
| 804-Y14750R14300B9R-ND | Y14750R14300B9R |
| 804-Y14750R10000B0R-ND | Y14750R10000B0R |
| 804-Y14750R12000B9R-ND | Y14750R12000B9R |
| 804-Y14750R03000B9R-ND | Y14750R03000B9R |
| 804-Y14750R02500B0R-ND | Y14750R02500B0R |
| 804-Y14750R07500B9R-ND | Y14750R07500B9R |
| 804-Y14750R07500B0R-ND | Y14750R07500B0R |
| 804-Y14750R15000B0R-ND | Y14750R15000B0R |
| 804-Y14750R08330B9R-ND | Y14750R08330B9R |
| 804-Y14750R06600B9R-ND | Y14750R06600B9R |
| 804-Y14750R13500B0R-ND | Y14750R13500B0R |
| 804-Y14750R03967B0R-ND | Y14750R03967B0R |
| 804-Y14750R15000B9R-ND | Y14750R15000B9R |
| 804-1176-ND | Y14720R01000E9W |
| 804-Y14750R10000F4W-ND | Y14750R10000F4W |
| 804-Y14750R05000F4W-ND | Y14750R05000F4W |
| 804-Y14750R02000F4W-ND | Y14750R02000F4W |
| 804-Y14750R12500D4W-ND | Y14750R12500D4W |
| 804-Y14750R20000D4W-ND | Y14750R20000D4W |
| 804-Y14750R06200D4W-ND | Y14750R06200D4W |
| 804-Y14750R05000D4W-ND | Y14750R05000D4W |
| 804-Y14750R02000D4W-ND | Y14750R02000D4W |
| 804-Y14750R10000D4W-ND | Y14750R10000D4W |
| 804-Y14750R10000C4W-ND | Y14750R10000C4W |
| 804-Y14750R02000C4W-ND | Y14750R02000C4W |
| 804-Y14750R10000B4W-ND | Y14750R10000B4W |
| 804-Y14750R02000B4W-ND | Y14750R02000B4W |
| 804-Y14750R05000B4W-ND | Y14750R05000B4W |
| Y14750R20000E4W-ND | Y14750R20000E4W |
| Y14750R20000B4W-ND | Y14750R20000B4W |
| 804-Y14750R03000F4R-ND | Y14750R03000F4R |
| 804-Y14750R10000F4R-ND | Y14750R10000F4R |
| 804-Y14750R12500F4R-ND | Y14750R12500F4R |
| 804-Y14750R04490F4R-ND | Y14750R04490F4R |
| 804-Y14750R05000F4R-ND | Y14750R05000F4R |
| 804-Y14750R04000F4R-ND | Y14750R04000F4R |
| 804-Y14750R02000F4R-ND | Y14750R02000F4R |
| 804-Y14750R16000D4R-ND | Y14750R16000D4R |
| 804-Y14750R05000D4R-ND | Y14750R05000D4R |
| 804-Y14750R02000D4R-ND | Y14750R02000D4R |
| 804-Y14750R10000D4R-ND | Y14750R10000D4R |
| 804-Y14750R12500D4R-ND | Y14750R12500D4R |
| 804-Y14750R03000D4R-ND | Y14750R03000D4R |
| 804-Y14750R02500D4R-ND | Y14750R02500D4R |
| 804-Y14750R20000D4R-ND | Y14750R20000D4R |
| 804-Y14750R10000F5W-ND | Y14750R10000F5W |
| 804-Y14750R04000F5W-ND | Y14750R04000F5W |
| 804-Y14750R20000F5W-ND | Y14750R20000F5W |
| 804-Y14750R10000C4R-ND | Y14750R10000C4R |
| 804-Y14750R02000C4R-ND | Y14750R02000C4R |
| 804-Y14750R10000D5W-ND | Y14750R10000D5W |
| 804-Y14750R20000D5W-ND | Y14750R20000D5W |
| 804-Y14750R06200D5W-ND | Y14750R06200D5W |
| 804-Y14750R02000D5W-ND | Y14750R02000D5W |
| 804-Y14750R05000D5W-ND | Y14750R05000D5W |
| 804-Y14750R04300B4R-ND | Y14750R04300B4R |
| 804-Y14750R03000B4R-ND | Y14750R03000B4R |
| 804-Y14750R06500B4R-ND | Y14750R06500B4R |
| 804-Y14750R10000B4R-ND | Y14750R10000B4R |
| 804-Y14750R02000B4R-ND | Y14750R02000B4R |
| 804-Y14750R05000B4R-ND | Y14750R05000B4R |
| Y14750R20000E4R-ND | Y14750R20000E4R |
| Y14750R20000B4R-ND | Y14750R20000B4R |
| Y14750R20000E5W-ND | Y14750R20000E5W |
| Y14750R20000B5W-ND | Y14750R20000B5W |
| 804-Y14750R03000D5R-ND | Y14750R03000D5R |
| 804-Y14750R20000D5R-ND | Y14750R20000D5R |
| 804-Y14750R02000D5R-ND | Y14750R02000D5R |
| 804-Y14750R05000D5R-ND | Y14750R05000D5R |
| 804-Y14750R10000D5R-ND | Y14750R10000D5R |
| 804-Y14750R04300B5R-ND | Y14750R04300B5R |
| 804-Y14750R06500B5R-ND | Y14750R06500B5R |
| 804-Y14750R05000B5R-ND | Y14750R05000B5R |
| 804-Y14750R02000B5R-ND | Y14750R02000B5R |
| Y14750R20000E5R-ND | Y14750R20000E5R |
| Y14750R20000B5R-ND | Y14750R20000B5R |
| Y14750R00100D0R-ND | Y14750R00100D0R |
| Y14750R00100D9R-ND | Y14750R00100D9R |
| Y14750R00500B0R-ND | Y14750R00500B0R |
| Y14750R00500F9R-ND | Y14750R00500F9R |
| Y14750R00300B9W-ND | Y14750R00300B9W |
| Y14750R00500B0W-ND | Y14750R00500B0W |
| Y14750R00600B9W-ND | Y14750R00600B9W |
