Clearance Hole in bulkhead
------Question for PT02H-12-8P Please Put your question below------What diameter clearance hole is needed for the contacts?
Hi billhomberg,
Welcome to the TechForum.
I found the following on page 23 (pdf page 25) of the PT Series catalog:
From this, the maximum diameter of the dimension “N”, which would need to fit into that cut-out hole is 0.782".
Page 49 (pdf page 51) of the same document gives actual cut-out recommendations:
So, the hole cut-out for the PT02H-12-8P, dimension “N” above, is 0.801".
