Amphenol Coaxial Cable & Connector Guide helps you view coaxial cable specifications and compatible RF connectors. Click Here for the interactive guide which will lead you to part numbers.
Flexible Coaxial Cable
Flexible cables, originally designed for military applications, are now also used in many commercial applications including data transmission, video processing and wireless connectivity. Flexible cables can be terminated to a wide range of connector choices including BNC, SMA, N-Type and TNC and are ideal for use for low and mid-frequency applications.
Features & Benefits:
Wide selection for a broad range of applications and
performance requirements -
Ideal for internal and external applications
50 and 75 ohm options available Applications:
GPS
CATV
LAN/WAN
LOW LOSS CABLE
LMR® cables offer high performance and flexibility in 50 ohm configurations, ideal for broadband and wireless applications. These cables are commonly terminated with BNC, TNC, SMA and N-Type connectors.
Efficient and reliable shielding provides low signal loss
Offers tight minimum bend radius
Ideal for use in outdoor applications. Direct burial options available. Applications:
Wireless infrastructure
Antenna jumper cables
Industrial applications
SEMI-RIGID AND CONFORMABLE CABLE
Semi-Rigid and conformable cables are widely used in precision applications requiring high shielding effectiveness. The below cables can be terminated to a wide range of connector choices including SMA, TNC, or MCX.
Conformable cable can be hand-formed without
specialized tooling -
Ideal for Low PIM applications (when terminated
to appropriate connectors) -
Commonly used in high frequency internal applications Applications:
Telemetry Applications
Amplifiers and Microwave products
Radar Equipment
Summary
Cable Type Impedance
(Ohms) Max. Attenuation
@ 400 MHz
(DB/100ft) Min. Bend
Radius
(Inches) OD
(Inches) Max Temp
(Celsius) Product Links
RG-6 76 5.6 1.65 0.332 +80 Connectors
RG-8 52 4.2 2.00 0.405 +80 Connectors
RG-8X 50 7.7 2.50 0.242 +80 Connectors
Cable Assemblies
RG-11 53.5 11.7 1.00 0.200 +80 Connectors
RG-55 53.5 9.4 1.00 0.195 +80 Connectors
RG-58 53.5 9.4 1.00 0.195 +80 Connectors
Cable Assemblies
RG-59 75 6.9 1.20 0.242 +80 Connectors
Cable Assemblies
RG-59 20AWG 75 16.0 5.00 0.242 +80 Connectors
RG-59 Plenum 75 5.9 2.00 0.190 +80 Connectors
RG-62 93 8.0 2.25 0.242 +80 Connectors
RG-142 50 7.8 1.00 0.195 +200 Connectors
Cable Assemblies
RG-174 50 17.0 0.48 0.100 +80 Connectors
Cable Assemblies
RG-178 50 29.0 0.40 0.072 +150 Connectors
Cable Assemblies
RG-179 70 21.0 1.00 0.100 +150 Connectors
Cable Assemblies
RG-179DB 75 21.0 0.40 0.125 +150 Connectors
RG-188 93 20.0 0.50 0.105 +250 Connectors
RG-213 50 4.2 2.00 0.405 +80 Connectors
RG-214 50 4.7 2.00 0.425 +80 Connectors
RG-223 50 8.2 1.00 0.211 +80 Connectors
RG-316 50 16.2 1.00 0.102 +200 Connectors
Cable Assemblies
RG-316DB 50 16.2 1.00 0.102 +200 Connectors
Cable Assemblies
RG-400 50 9.0 1.00 0.195 +200 Connectors
View All Connectors
View All Cable Assemlies
Also view our Crimp Tooling and Die Sets
@ 400 MHz
Radius
(Inches) OD
(Inches) Max Temp
LMR-100A-PVC 50 14.9 0.25 0.100 +85 Connectors
Cable Assemblies
LMR-195 50 7.3 0.50 0.195 +85 Connectors
Cable Assemblies
LMR-200 50 6.6 0.50 0.200 +85 Connectors
LMR-240 50 5.0 0.75 0.240 +85 Connectors
Cable Assemblies
LMR-300 50 4.0 0.88 0.300 +85 Connectors
LMR-400 50 2.5 1.00 0.405 +85 Connectors
Cable Assemblies
LMR-600 50 1.6 1.50 0.590 +85 Connectors
View All Connectors
@ 400 MHz
Radius
(Inches) OD
(Inches) Max Temp
RG-401 / 0.250 SR 50 4.6 0.50 0.250 +200 Connectors
RG-402 / 0.141 SR 50 7.2 0.15 0.141 +200 Connectors
Cable Assemblies
RG-405 / 0.085 SR 50 13 0.10 0.085 +200 Connectors
Cable Assemblies
0.047 SR 50 24 0.05 0.047 +150 Connectors
View All Connectors
View All Cable Assemlies Amphenol RF Part Search
Filter Results By: In Stock Lead-Free RoHS Compliant
Brochures
Product Training Modules
- SMA and N-Type Low Loss Cable Connectors
- BNC Overview
- ARC Rugged Product Line Overview
- FAKRA Series
- HD-BNC 50 Ohm
- HD-BNC™ High-Density BNC
Featured Products
