------Question for RR111C1921 Please Put your question below------
Is this switch compatible with xm1-15 xunma?
Thank you for your inquiry and welcome to the community.
I haven’t been able to track down the mounting dimensions of your switch but eyeballing it it doesn’t look like it would be a physical match to the mounting hole dimensions of RR111C1921 which is a circular panel cutout dimension of 20mm ( 0.787inch )
Do you know what the precise panel cutout dimensions of XM1-15 are? Are you able to measure?
