Component description/ part number
------Question for M2012SS1W45 Please Put your question below------
Description / Mounting type is confusing [Panel Mount, Right Angle, Vertical]
Hello GymM,
What the description means, is the part has a threaded bushing, so it mounts in a panel. It has through hole pins for the PCB board, and it mounts in a right angle to the board. The vertical part of the description is the direction that the toggle will move, which is Up and Down, when switching from one position to the other.
