Greetings all. I am attempting to fix some AMD BC250’s. I am a novice wish to ask your advice in identifying some parts. My boards are the same model but unfortunately some of the components differ. The component I am trying to replace seems to have been installed by someone unskilled at soldering. I hope the attached pictures could help in identifying the components. Hopefully Digikey carries them. Thank you in advance and to any advice is welcome and appreciated.
Hello!
I believe its a 0.68uH inductor. Check this out:
Hello xyzb33s,
I’m not certain but the R68 device might be an inductor at 0.68uH (680nH) value that is surface mounted package. Some similar of those we have here: Fixed Inductors | Inductors, Coils, Chokes | DigiKey
I wasn’t able to find much on the devices on the BC250, some info I found is here: AMD BC250 Documentation If you have a manual that shows the devices on the board that would be most helpful.
