Configurable Switch Components - Illumination Source
This Product Selection Guide contains information to help select products in the Configurable Switch Components - Illumination Source category on DigiKey.com
Configurable switches are modular electromechanical switch systems that allow users to assemble a switch to suit their specific needs, and which are well-adapted for use in many industrial or machine control applications. “Illumination Source” components for such devices include lamps and lamp holders adapted for use with such products, either as replacement components or parts for original assembly.
SelectionCharacteristics
Type: Refers to the method or technology used to provide illumination.
Color: Indicates the color of the light source.
Voltage: Indicates the nominal operating voltage of a product’s illumination.
Compatible Series: Indicates the manufacturer’s product series with which a device is compatible.
ProductExamples
MFR PART # 1.90.690.333/0000
DIGI-KEY PART # 1715-1.90.690.333/0000-ND
MANUFACTURER RAFI USA
DESCRIPTION Configurable Switch Lamp LED Yellow 24V
DATASHEET Click Here
MFR PART # 10-2312.1062
DIGI-KEY PART # 1948-1130-ND
MANUFACTURER EAO
DESCRIPTION Configurable Switch Lamp LED Red 24V
If you have any general questions on the specifications for selecting Configurable Switch Components - Illumination Source, please reply using the button below. If you have questions on specific Configurable Switch Components - Illumination Source please post those questions in the Electromechanical Switches category.
