Confirmation Request: Whether It Is the Same Product We Are Using
------Question for UDZSTE-175.1B Please Put your question below------
We are currently using UDZS NP TE-175.1B.
Please confirm whether this is the identical product.
Hello aaron.jeon,
I was unable to find any reference to the UDZSNPTE-175.1B part number, so I don’t know if they would be exactly the same. Since you are using that part, you can compare the information on the UDZSTE-175.1B, to your application, to determine if it would be compatible.
My guess is that it would be the same part or comparable, but it is up to you to verify if it is compatible for your application. The UDZSTE-175.1BTR-ND in our system is listed as a “Last Time Buy” status, so we will not be able to order any additional stock after July 10, 2026.
