Hello everyone,
I need help confirming whether the following resistor is the correct replacement for my Aim-TTi CPX400S bench power supply.
Original component markings:
- Manufacturer: Isabellenhütte
- Marking: PBV R010 0.5
- Package: Through-hole, 4 terminals
Proposed replacement:
- Part number: PBV-R010-F1-0.5
- DigiKey part number: 4423-PBV-R010-F1-0.5-ND
- Resistance: 10 mΩ
- Tolerance: ±0.5%
Could someone please confirm the following?
- Is PBV-R010-F1-0.5 the exact replacement for the original component?
- Does the F1 version have the same power rating, dimensions, and terminal configuration?
- Is this part suitable for use in the Aim-TTi CPX400S power supply?
I have attached photos of the original component and the proposed replacement listing for reference.
Thank you for your assistance.
