Connector for Hilux ln130 coolant sensor
Hi There,
I have a sensor part # 8942820100 for a japanese Hilux truck 92 Engine ln130. 2lte
I’m looking for a 18mm long. 2.68mm high 2.82mm wide. connector to fit this a standard 150 metri pack is just too small.
Hello mcgrathchilliwack,
I could not ID that socket contact exactly. I looked at some results for the LN130 online but could not verify which exact connector that was within our stock. Do you have pictures of the housing? We might be able to locate it that way. It’s not easy to locate the contact itself without knowing what housing it goes in.
Thanks,
@mcgrathchilliwack The Metri 150 is a connector from Aptiv. They are currently not a supplier that we carry. We would not have a contact that matches the connector housing that you are looking for.
Oh yeah, metripack is Aptiv I forgot about that.
its similar to a metric pack, thats the closet i have found, measurements are of what I need to replace….see picture of the housing
