Connector
Mr cool mini split male aux connector, looking for female mate. Thank you
Hello @porta235g,
Thank you for your post.
I am not seeing an exact match in our system, but the closest I could find in our system is our number A121755-ND.
280628 TE Connectivity AMP Connectors | Rectangular Connector Housings | DigiKey
The main thing to keep in mind is the pitch (pin spacing).
The suggested contact for our housing is the number A100441CT-ND
1-86557-9 TE Connectivity AMP Connectors | FFC, FPC (Flat Flexible) Connector Contacts | DigiKey
Hi, thanks . Someone mentioned https://www.digikey.com/en/products/detail/molex/0522660211/1776936
What do you think
Hi will this match? https://www.digikey.com/en/products/detail/molex/0522660211/1776936
The image you provided above looks an awful lot like this guy:
Assuming that’s what you have, the mate would be:
Associated contact:
Thanks,ill look into it
