I’m inquiring about more information pertaining to the Mini-Fit Connectors and the durability cycle (max mating cycle). Do you manufacture / produce or have any similar part number that exceeds the existing durability cycle of 30?
I provided some similar alternatives below but unfortunately we are unable to sort/filter by the durability or max mating cycle so please check the datasheets to see if they are a better fit for your application.
For stocking alternatives to the 39288240, click HERE.
For stocking alternatives to the 0039288080, click HERE.
For stocking alternatives to the 39288040, click HERE.
For stocking alternatives to the 39288060, click HERE.
Please check the datasheet for mating cycle information to see if they will work for you. The associated mating connectors for these can be found at the bottom of the product page under “associated product”.
