Contacten en instructies
------Question for LPT06SE-16-26S(072)(LC) Please Put your question below------
I would like to ask for your advice regarding the compatible contacts for this connector.
We have ordered this connector; however, as it is an LC type (less contacts), we also require the corresponding contacts separately.
Could you please confirm which contacts are compatible with this connector? Furthermore, could you provide the assembly instructions for this type ?
Connector type: LPT06SE-16-26S(027)
Welcome to the TechForum.
I was able to locate the correct contacts for that part on the below link.
Size #20 contacts
LPTC-SF-20S-20-3
https://www.digikey.com/en/products/detail/amphenol-industrial-operations/LPTC-SF-20S-20-3/28769626?s=N4IgjCBcoLQCxVAYygMwIYBsDOBTANCAG4B2aWehA9lANogDsADE8yALqEAOALlCCAC%2BwoA
This part has similar contacts and also has training modules attached below the parameters.
206485-1 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
Thank you
Ryan
Hello Ryan,
Thank you for your message and for providing the links and part numbers.
I appreciate you taking the time to locate the correct contacts for the Size #20 configuration. I will review the Amphenol and TE Connectivity options, including the training modules you mentioned.
If I have any further questions after reviewing the information, I will reach out.
Thank you again for your support.
Kind regards,
Osama
