------Question for 928205-2 Please Put your question below------
I purchased the connector with code 928205-2 and also the terminal with code 182734-2, which was indicated as compatible. However, it is not possible to use this terminal with the connector because the locking positions are different and the terminal does not fit properly into the housing.
Could you please provide the correct terminal part number that should be used with the 928205-2 connector?
Thank you in advance for your support.
