CRGCQ0402J10M Resistor
Could you please advise the differences between the two products below? Thank you.
https://www.digikey.com/en/products/category/resistors/2?s=N4IgTCBcDaIMICUDicCKAGALOsApAjOgLIgC6AvkA
Hello @ttalabsri
Welcome to the community!
Both are for the same manufacturer part number (CRGCQ0402J10M), so there is no difference in the resistor itself.
The only difference is the DigiKey ordering option and packaging:
One is stocked and available in Cut Tape, Digi-Reel®, and Tape & Reel, while the other is a Tape & Reel option with a 40,000 minimum order quantity.
Resistors | Chip Resistor - Surface Mount | DigiKey
