Cross-reference components TO 247
Hello
I have a few components to replace because I don’t know which ones are bad.
Original
KSF60F60B diode TO247
2SK1573 N-ch Mosfet TO247
FGW60N65WD IGBT TO247
2SJ352 P-ch Mosfet TO247
The ones I found
VS-60APU06-N3 Diode
TK20N60W,S1VF N-ch
AFGY100T65SPD IGBT
IRFP9240PBF P-ch
I found the P-ch Fet pins are not a match
but I dont know if I can locate better parts
Hello Power1,
I’m glad you were able to find some alternates.
I checked for a cross for the 2SJ352 P-CH Mosfet, but I was unable to find any possible match with the same pinout, in the order of #1=Gate, #2=Source, #3=Drain.
If you can insulate and bend the wires in the correct location for the IRFP9240PBF, you have to be careful, because the mounting hole is isolated, but the metal pad on the back will still be connected to the Drain, instead of the Source, so it can not be attached to the same spot, which will probably short out the mosfet or the system.
