Digi-Key will make ribbon cable assemblies from the IDC connectors that we stock from our
vendors. They are listed as a Value-Add item on our web site. Cable assemblies can be made with connectors on both ends or with a connector on one end. They also can have different connectors on each end as long as the number of conductors are the same.
There will be a setup fee involved for all new custom cables.
Please Contact custom.orders@digikey.com with any questions on the assemblies.
For Example we will use the Digi-Key part number A3AAH-1406G-ND
The Description will show it as IDC CABLE - ASC14H/AE14G/ASC14H
The ASC14H-ND is the connector part number. This will be on both ends of the cable assembly.
The AE14G-300-ND will be the part number for the cable that is used.
The Cable Assembly part number breakdown will be:
The Connector part Number breakdown will be:
Connector Options
Sockets
SC - STANDARD - OPEN END
SR - STANDARD - OPEN END W/STRAIN RELIEF
SL - STANDARD - OPEN END W/STRAIN RELIEF & PULLTAB
KC - STANDARD - OPEN END W/POLARIZING KEY
KR - STANDARD - OPEN END W/POLARIZING KEY & STRAIN RELIEF
KJ - STANDARD - OPEN END W/POLARIZING KEY, STRAIN RELIEF & PULL TAB
SD - STANDARD - CLOSED END
SS - STANDARD - CLOSED END W/STRAIN RELIEF
SM - STANDARD - CLOSED END W/STRAIN RELIEF & PULL TAB
KK - STANDARD - CLOSED END W/POLARIZING, STRAIN RELIEF & PULL TAB
KN - STANDARD - CLOSED END W/POLARIZING KEY
KP - STANDARD - CLOSED END W/POLARIZING KEY & STRAIN RELIEF
SN - STANDARD - CLOSED END W/OUT POLARIZING KEY
SP - STANDARD - CLOSED END W/OUT POLARIZING KEY W/ STRAIN RELIEF
SA - 2MM OPEN END
SE - 2MM OPEN END W/STRAIN RELIEF
TA - 2MM OPEN END W/POLARIZING KEY
TE - 2MM OPEN END W/POLARIZING KEY & STRAIN RELIEF
PIN/PLUG CONNECTORS
PK - POLARIZING KEY W/OUT FLANGE
PR - POLARIZING KEY & STRAIN RELIEF W/OUT FLANGE
PH - POLARIZING KEY, STRAIN RELIEF & PULL TAB W/OUT FLANGE
PL - POLARIZING KEY W/FLANGE
PS - POLARIZING KEY & STRAIN RELIEF W/FLANGE
PJ - POLARIZING KEY, STRAIN RELIEF & PULL TAB W/FLANGE
PA – POLARIZING KEY, W/O FLANGE, W/SHORT LATCH
PB – POLARIZING KEY, W/O FLANGE, W/LONG LATCH
PP - POLARIZING KEY, W/FLANGE, W/SHORT LATCH
PT - POLARIZING KEY, W/FLANGE, W/LONG LATCH
PCB CONNECTORS
PC - SPECIAL CENTER
PF - FULL ROW
PS - SHORT ROW
CARD EDGE CONNECTORS
CE - CARD EDGE CONNECTOR - W/OUT FLANGE
CF - CARD EDGE CONNECTOR - W/FLANGE
CS - CARD EDGE CONNECTOR - W/SLOTTED FLANGE
CG - CARD EDGE CONNECTOR - STRAIN RELIEF W/OUT FLANGE
CH - CARD EDGE CONNECTOR - STRAIN RELIEF W/FLANGE
CJ - CARD EDGE CONNECTOR - STRAIN RELIEF W/SLOTTED FLANGE
DIP CONNECTORS
DM - DIP CONNECTOR - .100 X .100
DP - DIP CONNECTOR
DR - DIP CONNECT0R - W/STRAIN RELIEF
DS - DIP CONNECTOR - .100X.100 W/RETENTION LEG’S
D-SUB CONNECTORS
MS - MALE D-SUB - PLASTIC SHELL W/THROUGH HOLE FLANGE
FS - FEMALE D-SUB - PLASTIC SHELL W/THROUGH HOLE FLANGE
MR - MALE D-SUB - METAL SHELL W/THROUGH HOLE FLANGE
FR - FEMALE D-SUB - METAL SHELL W/THROUGH HOLE FLANGE
MP - MALE D-SUB - PLASTIC SHELL W/ST-RELIEF & THROUGH HOLE FLANGE
FP - FEMALE D-SUB - PLASTIC SHELL W/ST-RELIEF & THROUGH HOLE FLANGE
MM - MALE D-SUB - METAL SHELL W/ST-RELIEF & THROUGH HOLE FLANGE
FM - FEMALE D-SUB - METAL SHELL W/ST-RELIEF & THROUGH HOLE FLANGE
ML - MALE D-SUB - METAL SHELL W/THREADED INSERT
FL - FEMALE D- SUB - METAL SHELL W/THREADED INSERT
MU - MALE D-SUB - METAL SHELL W/STRAIN RELIEF & THREADED INSERT
FU - FEMALE D-SUB - METAL SHELL W/STRAIN RELIEF & THREADED INSERT
MV - MALE D-SUB - PLASTIC SHELL W/THREADED INSERT
FV - FEMALE D-SUB - PLASTIC SHELL W/THREADED INSERT
MN - MALE D-SUB - PLASTIC SHELL W/THREADED INSERT & STRAIN RELIEF
FN - FEMALE D-SUB - PLASTIC SHELL W/THREADED INSERT & STRAIN RELIEF
