#D38999/25NB35PN
hello i am gonna buy this thing to put my cryostat feedthrough hole which has aluminum flange with hole.
but at the datasheet it says solder mount.
i am wonderin if it is possible to soler it to aluminum. or what elsi i need to do.
thanks.
I believe for a hermetic seal you need it to be soldered in place.
You can not solder to aluminum, so I don’t think you can get a truly hermetic seal easily.
However, if you don’t need a true hermetic seal, you can probably use some epoxy, or improvised hardware, to attach the connector to an aluminum tube.
Thanks a lot
which epoxy do you offer?
for example; colorless epoxy?
I’m just a forum member and not familiar with the epoxies sold by Digi-Key. Somebody else may have recommendation.
ok thx
PaulHutch via Engineering and Component Solution Forum - TechForum │ Digi-Key <notifications@digikey.discoursemail.com>, 3 Nis 2023 Pzt, 18:24 tarihinde şunu yazdı:
Hello!
Some clear epoxy
These are listed to handle aluminum and steel.
ok thx a lot
Nathan_2268 via Engineering and Component Solution Forum - TechForum │ Digi-Key <notifications@digikey.discoursemail.com>, 3 Nis 2023 Pzt, 18:27 tarihinde şunu yazdı:
