Can some one recommend Pin compatible Right angle Male with PCB mount Connectors with 9 pin and 50 Pin
Same way need pin compatible mating Female connector with straight(Solder type) with cover single ended cable
Also looking Female to female 50 pin connectors with 50 feet length cable ( Connectos should be compatible with DB50R/A ( i am able to see connectors but when mating side facing problem so requesting you to select both
