------Question for RK09L12D0A1T Please Put your question below------
I am looking for a specific replacement potentiometer from the Alps Alpine RK097 series, commonly used in Pioneer DJ equipment (Pioneer Parts: DCS1100 or DCH1265).
I have been unable to find this exact combination using the website filters. Could you please check if you have a model with the following specifications in stock?
Series: RK097 (Dual Gang / 6 Pins)
Resistance: 10k Ohms
Taper: Linear (B)
Actuator Type: Flatted Shaft (D-type)
Actuator Length (L1): 20.00 mm
Mounting Type: Snap-in (with mounting bracket/tabs)
Special Feature: Must have Center Detent (Center Click)
Switch: None (No push switch)
Does DigiKey carry a part number that matches all these requirements, particularly the Center Detent and the 20mm Flatted Shaft?
