Defining hole size & solder mask for finished results
Do the vendors ALL increase drill hole sizes to accommodate for plating thickness, and solder mask for pads’ specifications for clearance, or do I need to oversize everything before uploading drill & mask files? And by how much? Can’t believe this is not in FAQS.
Thanks, Al
Greetings,
Drill compensation for plating thickness and removal of silkscreen overlapping exposed copper are typical industry practices.
Most soldermask features will be built as the supplied files indicate, since customer preferences and design intents in such matters are less universal.
Our plating thickness for boards is located under 2 Layer Stack-up Document Here: DKRed | DigiKey
The plating thickness is 1mil ( 0.0254mm ). Which means for the overall diameter both sides of hole would add up to 2mil ( 0.0508mm ) .
Thanks, Kristof, but this doesn’t actually answer the question. Does your board house for red increase drill sizes 2 mils over specified so that finished plated holes end up the diameter specified in the .drl file?
It answers your ‘By How Much?’ question. You need to oversize holes to factor in the plating thickness.
Short answer from production side: most fab houses want FINISHED hole size in the drill file. They drill smaller themselves and plate up to your number. You usually do not oversize the holes in Gerber before upload.
Some houses work the other way (tool size = drill size, you must add plating). So one rule does not fit all. Before you change files, ask DKRed / your board house in one line: “drill file = finished or tool size?”
For soldermask clearance, leave it to their CAM unless you have a special reason. Expanding mask yourself often fights their default.
Which house you use besides DKRed, or only DigiKey Red for now?
