------Question for QFR0824HHP0 Please Put your question below------
My customer has requested the following Delta fan QFR0824UH-ESS 24V 0,44A.
Can you confirm the correct model number on your webshop?
Hello @paul6
welcome to the community!
Sorry, I am unable to find any detailed information for the part number QFR0824UH-ESS. It might be an older part version.
However, there are other fans with the same voltage and current ratings — you can check those to see if any part matches your requirements.
Dimensions are 80 mm × 80 mm (square).
DC Brushless Fans (BLDC) | Fans | FR0824UH_Delta Electronics
Hello paul6,
We have the QFR0824HHP0 in stock, but we do not carry the QFR0824UH-ESS fan.
I believe the QFR0824UH is a higher speed fan, and will have higher airflow. We have 3 options for the QFR0824UH. Click here for those available options.
Please check the datasheets and specifications for compatibility to your application.
If you need something different, please let us know all your requirements, and we can do further searching.
