------Question for ESP32-S3-BOX-3B Please Put your question below------
Are u able to provide SDK to implement?
Cause below is our reuqirement=>
- we need to retrieve the data stored inside the keycard’s MIFARE Classic blocks, specifically Block 20, which contains our dynamic Track 2–style data.
Example from our card:
Block 20 (HEX): 30 31 30 33 32 35 31 31 31 32 31 33 31 33 00 00
ASCII: ‘01032511121313’
This is the data we use for our system (room number + departure date).
The card UID (hex/dec) is not sufficient for our use case.
Since the Horus E2 device can only provide the basic UID and does not support reading MIFARE Classic sector/block data, could you confirm whether:
Any firmware option
SDK/API method
Or device configuration
would allow sector authentication (Key A/Key B) so that Block 20 data can be retrieved?
- QR Code Type (Dynamic or Static)
Our QR codes are dynamic.
eg., 9oTa0guCC76WuuxOSy+2+/Y8lQWvq5KSHabjcWv1xVaDFxYWS62/MT/Y1dp5/uia
