Digi Key PN#4955-F07320-ND
------Question for F07200 Please Put your question below------
Does Digi Key PN#4955-F07320-ND come with an adhesive backing?
thank you
Hello Craig,
Welcome to our community and thank you for using our forum.
Our team will look into that switch for you.
The 4955-F07320-ND snap dome switch does not come with an adhesive backing; it is a flexible metal element typically used as part of a layered assembly, and held in place using a flexible overlay material. The resource available at Metal Dome Switch Engineering Handbook - Snaptron | DigiKey may be helpful.
@craig.bush It is possible for us to special order a (custom) part as well if it is something we don’t normally carry.
Hello
We would be looking for something from their peel and place (PNP) arrays or adhesives.
Something like a F07320 but in a PNP with the adhesive backing.
What would be the digi-key p/n for that?
Thank you
This page on the manufacturer’s site offers a part number breakdown for their standard products in the peel and place packaging. If I read correctly, you’d want to request manufacturer part number PNP07(F07320).
That item is not present in the DigiKey listings currently, and as such there would be some delay and likely a minimum order quantity involved in procuring them for you; ordering from the supplier directly may be to your advantage.
Otherwise to special order through DigiKey, complete this form: Special Order Product Request
