Hi, I saw someone (Nick Carson) previously asked the same question about a different product, but I am wondering if you might be able to measure the length from the “top” of the ethernet port (where the connector exits port) to where the right angle ends for this product as well?
Hello msmall,
Our warehouse has changed, and we no longer have an easy way to have a part measured.
I checked the datasheet, and the manufacture’s website, and there are no detailed drawings with this dimension.
Looking at the post you mentioned, which was from 2022, the dimension for this cable would be close to the 17.6~17.9mm dimension, but we are unable to verify that.
You should contact the manufacture directly to have this dimension verified.
