------Question for HA-VGA-Y-BEI Please Put your question below------
Does this cable is pin to pin wired?
Pin1 → Pin1–> Pin1
Pin2–>Pin2–>Pin2
etc.
Pin1 → Pin1–> Pin1
Pin2–>Pin2–>Pin2
etc.
This part is a VGA cable. If the output pins did not match the input, it would defeat the use case that this part is for.
I’m not planning to use it as VGA cable, but more as an extender cable that requires pin to pin definitions.
Some VGA cables have some pins connected between them, like ground.
This is why I need to understand if this cable is pin to pin.
The MarketPlace supplier for this part does not have their pin to pin information available.
Yes I noticed this, this is why I raised this question.
