------Question for DMA15-AAAAA1 Please Put your question below------
What is the power cord part number for US?
The manufacturer lists the following M12 4 position Plug-Female Socket A-Coded cables as associated with DMA15-AAAAA1:
Otherwise we have other similar cables available in stock located below.
Circular Cable Assemblies | Cable Assemblies | DigiKey
No plug attached, just flying leads as they call them.
You’re expected to have something intended for what they call the ‘customer side’ in the below diagram. They just tell you in the datasheet which wire does what and provide recommended cables.
It’s not uncommon to do it this way with industrial sensors.
So, for this cable, is there manual?
How do we know which color represents what Pin Assignment?
https://www.digikey.com/en/products/detail/omega/71349261/27049971
I don’t see that they have published a pinout for that cable.
I’d advise buying another M12 4 position plug/female socket with A-Code that has proper documentation since they’re standardized connectors.
If you let me know what length cable you need we can advise further.
2 meters or 5 meters whichever available
