------Question for NUCLEO-F401RE Please Put your question below------
Not sure how to get this reset we have been switching the programmers to make it go away. Is this the programmer or the board we are programming? We are powering the controller and connecting with four pins from this programmer and and want to make sure also all the jumpers are correct for this application. We are only using this for Programming the STM on our controller and not the bottom half of this board.
Assuming you are programming the NUCLEO-F401RE, are you using an external programmer? Any reason you’re not using the built in ST-LINK/V2-1 programmer/debugger on it?
We are not using that pin. The controller is externally powered from our power supply. Do we need to connect this to our board but we are only powering the programmer from the USB port?
