------Question for ES1JL Please Put your question below------
ES1JL
Any official notification or PCN from the supplier/manufacturer regarding the part number marking change for the item below?
In addition, could you please confirm whether the suffixes “RVG” and “W” will be permanently removed from the manufacturer part number in future production?
Place order only use MPN: ES1JL ?
@gaikean.lim Welcome to DigiKey’s TechForum!
The first 2 digits are the packing code, and the last “G” means green compound.
The packing code could vary based on the package type and the reel size, but the part itself is the same. For example, ES1JL (1801-ES1JLTR-ND) and ES1JL RUG (ES1JLRUG-ND) are the same product with different packing code (different quantity per reel).
But for “W”, this is a part of the part number indicates that the package is “SOD-123W”, while ES1JL is Sub SMA. They have different package types.
Best regards,
Hi Brian,
I have load order with ES1JLW but incoming with ES1JL.
Kindly advise.
I’m sorry for any inconvenience this has caused.
If you have received ES1JLW (SOD-123W) instead of ES1JL (Sub SMA), this could be a picking error.
Please submit your case thru DigiKey’s Returns and Order Issues portal.
Best regards,
hi Brian,
i not sure is picking error or just label issue, can you help to advise
Once you submit your ticket, action will be taken accordingly. So, the first thing you will have to do is submitting a ticket for your case.
Best regards,
