We are experiencing a repeatable UBX-RXM-RAWX output failure on one EVK-X20P and would appreciate advice on whether this could be a firmware issue or defective hardware.
Setup
EVK-X20P-00 / ZED-X20P
Hardware:
000B0000 -
Firmware: HPG 2.02 (43e74c)
Protocol: 50.10
Connection: EVK USB-C to Linux/Raspberry Pi (
/dev/ttyACM0) -
Measurement rate: 2 Hz
UBX-RXM-RAWXandUBX-RXM-SFRBXenabled -
Supplied active all-band EVK antenna
We use essentially the same configuration procedure on three EVK-X20P units, but only this unit consistently shows the problem.
Failure
After a power cycle, RAWX starts normally.
Latest capture:
296 consecutive RAWX messages
Exactly 2.0000 Hz
100% of intervals = 0.500 s
Continuous RAWX span = 147.5 s
No missing epochs before the failure
Populated RAWX messages are approximately 2.4–2.9 kB
After 147.5 s, RAWX stops completely and does not resume
A previous capture showed the same behavior after 271 RAWX messages / 135 s, so the cutoff is repeatable but not at an identical elapsed time.
Importantly, the receiver itself continues operating after RAWX stops:
UBX-RXM-SFRBXcontinues -
UBX-NAV-PVTand other NAV messages continue -
Receiver maintains a 3D fix with ~27–28 satellites
No USB disconnect occurs
The host continues receiving valid UBX messages
Immediately after RAWX stops, the RAM configuration still reports:
CFG-MSGOUT-UBX_RXM_RAWX_USB = 1
CFG-MSGOUT-UBX_RXM_SFRBX_USB = 1
CFG-RATE-MEAS = 500
CFG-RATE-NAV = 1
Rewriting CFG-MSGOUT-UBX_RXM_RAWX_USB = 1 does not restore RAWX. Restarting the host-side logger also does not restore it. A power cycle reliably restores RAWX, but only temporarily.
We have also reset/restarted the EVK and reapplied the configuration, but the behavior remains.
Important comparison
There is a strong dependency on whether RAWX contains actual observations.
Without an antenna connected:
RAWX contains
numMeas = 0 -
Payload is only 16 bytes
Receiver ran for one full hour
Exactly 7,200 RAWX messages at 2 Hz
No interruption
With the supplied active antenna outdoors:
Approximately 76–90 observations per RAWX epoch
RAWX payload approximately 2.4–2.9 kB
RAWX stops after roughly 2–3 minutes
Other UBX messages and navigation continue normally
This makes us suspect an issue related to populated RAWX generation/output rather than a general USB or receiver failure.
Questions
Is this a known issue with HPG 2.02 on ZED-X20P / hardware 000B0000?
Is there a newer or recommended firmware version for this hardware?
For the EVK USB-C connection, should RAWX output be controlled by the
*_USBCFG-MSGOUT keys, or should*_UART1keys be used? -
Are there diagnostic messages you recommend capturing around the failure, such as
MON-TXBUF,MON-HW,MON-RF, orMON-MSGPP? -
Is there a supported command/reset that can restart RAWX generation without power-cycling the EVK?
Given that the same configuration is used on three EVK-X20P units and only this unit consistently fails, could this indicate a defective receiver/evaluation kit?
We can provide the original binary UBX captures from both the failing outdoor test and the one-hour no-antenna test, complete MON-VER output, configuration dumps, and host-side logs.
