------Question for 182206-2 Please Put your question below------
Apologies for the previous question… this question is looking for an extractor tool to be able to extract these 182206-2 pins into A121744-ND connectors, fix connections and re-pin with new pins.
I checked on DigiKey’s website, and the manufacture’s website, and I did not find a recommended extraction tool. However, they should not be too difficult to remove. On the side of the connector, there are rectangle opening, where the tab locks the contact into the housing. If you take a small jeweler’s screwdriver, or even a paperclip, and press the tab down, that should release the catch. If you are going to replace the contacts, pushing the tab in farther, should bend it enough to stay depressed, and you should be able to pull on the wire, to remove the contacts. Or use the paperclip to help push the pin out from where it usually mates to the other connector.
