F-337-C6050 - Storage and Operating Temp
------Question for F-337-C6050 Please Put your question below------
Please provide the operating and storage temperature for this part: F-337-C6050
Hello NotAName,
The manufacturer does not list an operating or storage temperature range.
Their Datasheet list temperatures of 22C (72F) and 70C (158F) in their compression set column.
The Peak Damping Performance Temperature ranges at different frequencies range from -17C to 46C. This is all I was able to find.
Hi David,
Thanks for the quick reply. I contacted the manufacturer regarding the storage and operating temperature and they recommended contacting DigiKey.
The temperatures in the datasheet are where the damping is effective but I assume the storage and operating temperatures for this material have a much wider range. We need to operate -25C to 55C and store from -40C to 85C. I don’t see why these parts wouldn’t work but the manufacturer should provide that information.
Any suggestions on how I can get that information?
