FDB-1032-SFP+ Evaluation Board
Hi everyone,
I’ve just purchased the FINISAR-FDB-1032-SFP+ evaluation board. I’ve only found the data sheet, where from the “GUI Installation” section (page 2), it is written the following: See the datasheet (FDB-INT-USB3) for the installation of the drivers necessary for the USB connection.
So I need:
* the USB driver (as described in the FDB-INT-USB3 document),
* and the Transceiver Workbench SFP GUI software.
Thank you very much for your support.
Hello rossella.centonze, welcome the TechForum.
I am checking with the manufacture on this one. Will let you know when I receive the information.
Thank you very much. I appreciate
Best regards,
Rossella.
I have another question: I am unsure about the exact connector size and type required for the power input. I would greatly appreciate it if you could provide guidance on the correct dimensions and any recommended compatible cables or power supplies.
Thank you in advance for your support.
I wasn’t able to find this information so I also sent this request to the manufacturer and will let you know when I receive the information.
Thank you.
Best regards,
Rossella.
I did get the part number to the DC power jack which is a Foxconn part JPD1135-509-7F. Unfortunately, I was not able to find a compatible cable or power supply to offer in our system.
Thank you for this reply. Maybe it can be useful to directly ask to Foxconn?
Rossella.cenonze,
I sent an update request to the manufacture.
Thank you.
Best regards,
Rossella.
Unfortunately I am not getting any feedback from the manufacture.
