Filter voltage compatibility
Hi, I reached out to the manufacturer of this item to verify it is compatible with a 120V 60Hz single phase circuit, but did not get a reply. All similar filters that are listed from this manufacturer on DigiKey are likewise rated at 250VAC, but I don’t know if this is the operating voltage or maximum voltage.
https://www.digikey.com/en/products/detail/dit/TBA-30B443A/18681212
Thanks!
Hi,
Thank you for your inquiry. 4761-TBA-30B443A-ND is rated for a max voltage of 250VAC, but will work well at 120VAC @ 60HZ single phase
