Is LTC4017 a flexible IC? or is a flexible version of it available?
Is there a PMIC for power harvesting you can suggest that is flexible?
*Flexible meaning being able to bend it.
Greetings,
LTC4017 is not currently a valid part number.
Regardless, the number of electronic components on the market that are truly flexible is essentially zero. Circuits built on flexible substrate materials typically avoid placing components near regions of flexure, use stiffening materials to make areas where components are placed rigid, use very small components oriented so as to reduce the amount of stress placed on solder joints due to bending, and/or other techniques to accommodate the mechanical mismatch between a rigid component and a flexible substrate.
