FLIR E96 Export File
When using the E96 Thermal Image Camera from FLIR, people sometimes wonder whether the captured image or video data can be exported in an MS Excel readable format or not?
FLIR’s response is that being able to export .CSV file of temperature data is dependent on what software is used.
For examples, data can be exported from Researcher in a variety of ways:
  1. If you select “Edit → Copy value” you can copy temperature or image data to another program as text.
  2. If you have an area box on the screen you can select “Image → Save area as” to save the contents as a CSV (comma separated values) file.
  3. If you create a time vs. temperature plot you can save the plot file and then open it from Excel. The temperature and time information will appear in separate columns.
Applicable Part Number
2067-90202-0101-ND
2067-90203-0101-ND
2067-90201-0101-ND
2067-90207-0101-ND
2067-90205-0101-ND
2067-90204-0101-ND
2067-90206-0101-ND
90202-0101
90203-0101
90201-0101
90207-0101
90205-0101
90204-0101
90206-0101
