From Sensor to Server: Temperature Monitoring over 10BASE-T1L with Analog Devices
Why 10BASE-T1L?
The industrial automation space increasingly requires networking solutions that provide high bandwidth, long range, streamlined connectivity, and sufficient power delivery. Single Pair Ethernet (SPE) is a perfect candidate to meet these requirements and, in particular, the 10BASE-T1L standard is uniquely suited for process, factory, and building automation applications. It utilizes shielded single twisted pair cable to deliver both power and data over long distances in a point-to-point topology. Through a backbone of power and field switches, networks can naturally be organized into a familiar trunk and spur topology to maximize scalability and accommodate hazardous areas.
10BASE-T1L offers several advantages over traditional 4 mA to 20 mA or field bus communication protocols. Perhaps most significant is its ability to support full-duplex, high-speed data exchange up to 10 Mb/s. This enables the integration of higher performance field level devices which can expose multiple process values and device parameters (e.g., configuration, predictive maintenance, and life cycle management parameters).
Its long range of 1000 meters generally meets or exceeds the baseline set by legacy communications standards. Furthermore, network installation requires less effort thanks to the smaller and lower cost single twisted pair cabling which can carry up to 60 W of power alongside the high-speed data. Consider also that cabling from legacy installations may be reusable if it meets the 10BASE-T1L channel model requirements (e.g., return loss and insertion loss).
Because 10BASE-T1L is defined at the physical layer of the OSI model, it is protocol-agnostic and can be integrated seamlessly with existing Ethernet subnets using any desired application-layer protocol. This could be an industrial automation protocol such as PROFINET, EtherNet/IP, HART-IP, or MODBUS TCP, as well as messaging protocols like MQTT. Complex gateways are not needed to benefit from the end-to-end IP connectivity and the simplified device commissioning and configuration which naturally follows.
Analog Devices offers several 10BASE-T1L physical layer products enabling long range Ethernet connectivity from the field level to the control level. This includes the ADIN1110 MAC-PHY, which allows Ethernet connectivity to be added to any microcontroller (MCU) over a SPI interface. Designers can therefore choose from the rapidly growing field of ultralow-power MCUs to create optimally efficient flow, level, pressure, and temperature sensors. Existing field instruments, sensors, and actuators are also easier to upgrade since the existing MCU can be retained if desired.
Other 10BASE-T1L Analog Devices products include:
  • The ADIN1100 PHY, ideal for more complex designs utilizing a more capable host MCU with an integrated MAC (evaluation board: EVAL-ADIN1100EBZ).
  • The ADIN2111 2-port switch with MAC and PHYs, useful for developing devices which may be daisy-chained (evaluation board: EVAL-ADIN2111D1Z).
Analog Devices offers several development tools (both hardware and software) to expedite the development of 10BASE-T1L devices using the ADIN1110. The remainder of the article describes a simple SPE networking demo built using these tools to illustrate this.
Demo Overview
This demo, shown below in Figure 1, features two devices on an isolated SPE network to showcase the versatility of 10BASE-T1L and how Analog Devices simplifies its integration into industrial systems. The first device acts as an industrial temperature sensor, periodically collecting temperature data and sending it to the second device over the network. The second device serves as an HMI, logging and visualizing the received temperature data. It also presents the user with options to change the sensor’s behavior and uses the Ethernet interface to communicate these configuration changes back to the sensor.
The AD-APARD32690-SL is an embedded evaluation board from Analog Devices which is intended for developing industrial field devices, making it a perfect fit for the sensor node in our example SPE network. It features the highly capable yet low-power MAX32690 MCU, which offers an industrial temperature range, a 120 MHz Cortex-M4 processor, a 32-bit RISC-V coprocessor, Bluetooth 5.2 LE, generous internal flash and SRAM, and an extensive set of communications peripherals. As previously mentioned, the onboard ADIN1110 MAC-PHY was utilized to establish 10BASE-T1L SPE connectivity for this host processor. Future work may make use of other board features such as its WiFi module (the NINA-W102 from u-blox) or the security coprocessor (the MAXQ1065). Of course, additional functionality can also be added by means of the Arduino and/or PMOD expansion headers.
For this application, we take advantage of the Arduino headers by using the MikroE Click shield as an adapter for the THERMO Click add-on board, which features the MAX31855 cold-junction compensated thermocouple-to-digital converter. The MAX31855 uses its 14-bit ADC to measure the thermoelectric voltage between the T+ and T- inputs of an external thermocouple, as well as its own internal temperature, which is assumed to equal the cold-junction temperature. It then performs cold-junction compensation to accurately determine the thermocouple temperature. Assuming no fault conditions were detected during the measurement (i.e., shorted or open-circuit conditions on the T+/T- inputs), the MAX32690 reads the temperature data from the MAX31855 and sends both the compensated thermocouple temperature and the cold-junction temperature to the HMI via the SPE connection.
The cold-junction compensation only produces an accurate result if the MAX31855 die temperature and the thermocouple’s cold-junction temperature are the same. For this demo, the THERMO Click board works well enough. However, applications demanding the highest accuracy may benefit from other solutions. See How Thermal Gradients Cause Thermocouple Measurement Errors for more information.
A simple Ethernet connected HMI was created with the help of Analog Devices’ EVAL-CN0575-RPIZ Raspberry Pi HAT. It provides a simple way to prototype with the ADIN1110 in an embedded Linux environment. SPI access to the MAC-PHY is part of its 40-pin header interface along with the I2C lines for the onboard temperature sensor (the ADT75) and GPIOs for both the pushbutton and LED. Optionally, developers can take advantage of the board’s Single Pair Power over Ethernet (SPoE) support to supply power to the carrier board using the 10BASE-T1L cable. However, because the AD-APARD32690-SL does not support SPoE by itself, we opted not to employ this option and instead power the carrier board (a Raspberry Pi 3B+, in this case) using an external power supply.
Implementation Details
For those looking to implement any aspect of this demo application, or for those who would simply like to learn more about its inner workings, this section should provide all the information required to replicate its functionality.
Materials List
The Temperature Sensor
The firmware running on the MAX32690 MCU is based on ADI’s bare metal software framework called no-OS. In addition to providing device drivers and a hardware abstraction layer, it also includes several example projects as a starting point, including a TCP echo server implementation for the AD-APARD32690-SL board. This echo server application served as the template for our final industrial temperature sensor prototype.
On startup, the program begins by initializing the network stack and opening a TCP socket on port 10000. It then enters the main loop where it continually listens for other devices on the network attempting to connect to the socket. Once a connection is established, the device begins periodically sampling temperature data from the MAX31855 (THERMO Click board) with help from the MAX31855 no-OS Driver. Each collected sample, which consists of both the cold-junction temperature and the compensated thermocouple temperature, is sent to the connected device over the socket.
Concurrently, data received through the socket is stored and parsed to determine whether it represents a valid command. For the time being, only two commands have been defined:
Command Description
INTERVAL <n> Sets the sampling interval, where n is the number of seconds between samples.
FILTER <state> Controls the digital filter, where state is 1 to enable the filter or 0 to disable it.
Although the application refers to this feature as a “filter”, it does not implement a true digital filter. Instead, a simple oversampling scheme is employed in which each reported thermocouple reading is the median of five samples collected in rapid succession. Enabling this “filter” may be necessary depending on the surrounding environment because thermocouples, while durable and excellent at measuring large temperature ranges, are generally quite sensitive to noise. What’s more, the THERMO Click board does not include the recommended 10 nF capacitor across the T+ and T- inputs, potentially exacerbating this sensitivity.
From the MAX31855 Datasheet under “Noise Considerations” (pg. 11):
The input amplifier is a low-noise amplifier designed to enable high-precision input sensing. Keep the thermocouple and connecting wires away from electrical noise sources. It is strongly recommended to add a 10nF ceramic surface-mount differential capacitor, placed across the T+ and T- pins, in order to filter noise on the thermocouple lines.
The environment used to develop this application was ADI’s CodeFusion Studio extension for VS Code. See the adi-apard-thermo-demo GitHub repository for the workspace source code. A few things worth noting regarding this code:
  • This is not the complete source code as it depends on ADI’s MSDK, which can easily be installed alongside CodeFusion Studio.
  • As currently configured, the THERMO Click board should be inserted into Slot 1 of the Click Shield.
  • The AD-APARD32690-SL does not include an onboard programmer/debugger, so an external programmer is required to program the board. Analog Devices recommends the MAX32625PICO in the AD-APARD32690-SL documentation.
The HMI
The EVAL-CN0575-RPIZ is very easy to get started with thanks to ADI Kuiper Linux, a Debian-based Linux distribution packaged with several ADI libraries, tools, and pre-configured applications. At the time of writing, the image_2026-09-21-ADI-Kuiper-Linux-arm64.img image is the most current Kuiper Linux release.
Testing revealed that the current image is noticeably more sluggish on older hardware (like the Raspberry Pi 3 Model B+ used in this demo) when compared to earlier releases. It may be worth considering either a hardware upgrade or an image downgrade depending on your requirements. For this demo specifically, reverting to a Debian Bullseye-based Kuiper release was perfectly sufficient.
With considerable assistance from Claude (Anthropic), an HMI application was developed in Node.js to run on the Raspberry Pi. It connects to the TCP socket opened by the MAX32690 on the AD-APARD32690-SL and plots the incoming sensor data as it arrives (see Figure 2). It also includes several user controls to adjust the plot view and modify the sensor behavior. The application code in its entirety can be found in the adi-cn0575-hmi-demo GitHub repository, alongside instructions for configuring the Pi and running the application.
Figure 2: A screenshot of the HMI’s Graphical User Interface (GUI)
Conclusion
This demo project features several solutions from Analog Devices to showcase the potential of 10BASE-T1L as an industrial networking technology. Although relatively simple, the demo can easily be expanded to accommodate longer cables, higher-bandwidth communications, and a broader range of industrial automation and telemetry protocols. Additional Analog Devices development platforms that implement media-conversion and field-switching functionality can be used to further scale the network and add more endpoints. By extending Ethernet connectivity to the field level, 10BASE-T1L can enable more connected, efficient, and maintainable automation infrastructure.
