GlobTek, Inc. produces a wide range of power supplies both on and off board to help make sure the magic smoke can find its way into your equipment, incluuding a number of interchangeable-blade wall warts like WR9QQ1800CCPNACIMR6B. We’ve had a number of questions on where to find replacement blades for this and other GlobTek wall supplies. Is there an easy way to do so?
Q-KIT-9(R) is an easy, single-part-number solution for acquiring any blades you may need, whether through loss or through going somewhere new and exciting. For replacing individual blades, the Blades-Q Series will be where you go to find new blades for these products.
