Hardware for the switch
------Question for FS57003PLT2B2M2QE Please Put your question below------
What are the part numbers for the mounting hardware for the switch?
Thank You,
Steve
Hello stephenmartin17,
This switch does not appear to come with the hardware, and the parts are not mentioned in the datasheet. Searching for a M12x0.75 hex nuts, I found part numbers 2449-CITHEXNUT12MMM12X0.75-ND and 141-RP8100HEXNUT-ND.
The closest lock washer I found is part number 360-3217-ND.
I did not find a flat washer.
