The other day I was working on my motorcycle and i had to remove the H4 (9003) Halogen bulb with the 3 quick connect tabs and accidentally broke the housing on the connector.
If this has ever happened to you? This is exactly what you need to fix it.
The connector housing is a TE AMP quick connect boot 172615-2 DigiKey part number A112671-ND
The H4 (also known as 9003) Halogen bulb has .312" tabs. Here are the quick connect terminal that will work with that housing.
172795-1 DigiKey part # A105444CT-ND 14-20AWG Quick Connect terminal
172796-1 DigiKey part # A101741CT-ND 14-16AWG Quick connect terminal.
