Help Building a Low-Cost DigiKey BOM for an Open-Source Pick-and-Place Test PCB
Greetings,
This is essentially a reverse-BOM exercise: the PCB footprints have already been defined, and I am trying to identify the least expensive DigiKey-orderable components that physically fit them. Electrical functionality is irrelevant because the PCB is solely for pick-and-place machine testing.
I’m a retired software developer who has been expanding his electronics interests into designing and assembling small PCBs. I’ve recently purchased an AFARCO V3 pick-and-place machine, which I expect to receive shortly. My objective is to bring more of the PCB assembly process in-house for prototypes and small production runs.
I recently joined the Google Groups OpenPnP community and raised the question of whether there is a pick-and-place equivalent of 3DBenchy, the inexpensive, standardized test model widely used to evaluate 3D printers.
A member of the OpenPnP community directed me to an existing open-source test PCB designed specifically to evaluate pick-and-place machines. I’ve cloned the project here:
The board contains a variety of SMT footprints, from 0201 resistors to more challenging packages such as QFN-32, TQFP-100, TQFP-144, TSSOP, TSOT, and several power-device packages.
The board has no functional electrical circuit. Its purpose is to test feeder operation, component pickup, vision alignment, rotation, and placement accuracy. What matters is that their physical packages match the PCB footprints.
I volunteered to develop a complete, inexpensive bill of materials that other OpenPnP users could use to populate this board.
What I’ve accomplished
I’ve exported the KiCad BOM and, with assistance, identified DigiKey-sourced 10 kΩ resistors for all five resistor footprints:
  • 0201 — 36 components per board
  • 0402 — 24 components
  • 0603 — 24 components
  • 0805 — 15 components
  • 1206 — 15 components
That’s 114 resistor placements per board.
I’ve calculated procurement quantities for assembling 1, 5, and 10 boards, allowing 10% extra resistors for pickup failures, lost components, and similar mishaps.
Where I’m seeking DigiKey’s assistance
The more challenging task is identifying the least expensive DigiKey-orderable components that physically match the remaining footprints.
For example, a 144-lead TQFP need not be a sophisticated or expensive processor. Any inexpensive device having the appropriate package dimensions and lead geometry would serve the purpose. Obsolete or otherwise unremarkable components would be entirely acceptable, provided they are available for purchase.
Ideally, the selected components would:
  • Precisely match the existing KiCad footprints.
  • Be the lowest-cost practical choices.
  • Be available in cut tape, trays, or other packaging compatible with pick-and-place operations.
  • Have sufficient inventory that multiple hobbyists could order the same parts.
  • Be reasonably likely to remain available, allowing others to reproduce the test in the future.
I would like to prepare a complete BOM showing DigiKey part numbers, unit prices, extended costs, packaging, and total component costs for 1, 5, and 10 boards.
Why I’m undertaking this
My hope is to make the completed BOM available to the OpenPnP community, along with my eventual experiences assembling the boards using the AFARCO machine.
I am not seeking donated components or financial sponsorship. I’m asking whether DigiKey’s technical engineers, with their familiarity with the catalog and available inventory, might be willing to help identify economical components that meet these mechanical requirements with the least amount of cost.
I recognize that this is an unusual sourcing exercise because electrical performance is irrelevant. In a sense, we’re shopping for packages rather than electronics.
If a DigiKey engineer would be interested in assisting, I can supply the exported BOM, KiCad design files, and my preliminary sourcing spreadsheet.
Thank you for considering the project.
John Poole
Salem, Oregon
Greetings,
The brevity of this line item obscures a lot of salient details pertaining to the object at hand, seeing as how PnP work is particularly interested in and contingent on the packaging modality of the devices to be planted. It might be said that the package itself is nearly as irrelevant as electrical function for these purposes, compared to the process by which the item gets presented to the pick head.
The resistors you’ve already identified are probably cheap enough to use live components, but the farther one goes from that sort of package the less practical it becomes. Taking the example of the 144-TQFP for example, live silicon in that package is probably going to run about $4 per unit, at a minimum.
Dummy components are a thing (example supplier here) though I’ve not known DigiKey to list/stock them, at least as of yet.
Feel free to share the list of packages you’re interested in, and any additional constraints that apply in regard to packaging. Chances are fair that some incremental progress could be made.
Thank you, Rick.
I was unaware of dummy component suppliers or that such a market exists. It may very well obviate the project I’m considering since an off-the-shelf testing kit may be available and answers the need.
Cheers,
John
Hello @jlpoole56,
DigiKey’s search engine is able to search by package type.
For example, 144-TQFP returns this selection.
From there you can select you candidate parts. In this particular case, the Microchip PIC32CK1025SG01144-I/4KB is a reasonable solution.
The search engine is sensitive to the exact keyword. For example, 144-TQFP and 144 TQFP yield close but distinctive results.
I will not speak for the other engineers. However, the catalog is overwhelming. I’m unable to hold more than a tiny fraction in my mind’s eye. The best I could do is a manual search as sugested in this note.
Sincerely,
Thank you @APDahlen . “search by package type” then sort by price: perfect.
And thank you to the software manger/designer for your database for exposing that field.
Dummy parts are good for big packages. For passives I would use real ones, 0402/0603 resistors on cut tape cost almost nothing.
Two things from our assembly side:
  1. Test also feeders and tape types you will really use, paper and plastic embossed tape behave different on pick.
  2. Check placement with paste on board, not only dry. Parts move on reflow, on dry board you dont see it.
