Help finding "common" right angle male header
Can anyone help me find a right angle male header connector with particular dimensions/specs. These seem to be really common on Amazon/Aliexpress/etc, but I want a Mfr/Part# for my BOM. The image is from a listing on Aliexpress. I’ve found a couple of connectors that are close, but not quite right.
Tail length: 6mm
Post length: 3mm
Distance from outside of tail to other side of base: 4.3mm
2.54 pitch, square posts/tails, tin plating
Hello FusedByDesign, welcome to the DigiKey TechForum,
The only options that I can find in our system that match the specs provided are linked HERE. These are right angle options with square contacts (with tin finish) that have a 3mm post and a 6mm tail.
