Hi Guys, Can you help us identify the correct socket and terminals we need to replace a damaged one on a rock crushing machine in a quarry?
The socket required is to fit on a Danfoss sensor, The Danfoss sensor is a 162U9904 and you can see the sensor info here
Ours has the AMP connector shown on page 7.
Below are pictures of the socket to be changed and also the plug on the existing sensor. Many thanks for any help, it is appreciated.
That would mate with A142569-ND which looks like what you have. You would need a lock plate A126076-ND and 3 contacts A107020CT-ND though I would order a couple extra to make sure you get a good crimp.
Spot on, they have arrived at the office and look to be the perfect match to what is on site:-
1 x A14269-ND Socket.
1 x A126076-ND Lock plate
10 x A122986CT-ND 16-20 Gauge wire crimp terminals.
Thanks again for the help.
