High Temperature LEDs
Operating conditions can be a challenge for any electronic component. For low-powered indication LEDs, the typical range is -40°C to 85°C. While the upper end of 85°C (185°F) seems high, devices can quickly reach and surpass this ambient temperature range when hundreds of components are firing simultaneously. This can quickly become problematic when a product is operating outdoors in the sun, or in a tight enclosed space where heat becomes trapped.
When LEDs are exposed to operating temperatures beyond the upper limit, several things may happen:
  1. Shift in color output (wavelength)
  2. Decreased intensity
  3. Rapid degradation of overall lifespan
To prevent this, make sure to select the right LED for the application.
SunLED has a line of High Temperature SMD LEDs that increases the upper temperature range limit to 100°C. This increase of +15°C makes these parts ideal for automotive applications such as interior dashboard and button backlighting where 100°C operation is generally considered a “hard” requirement.
Now as product design requirements have evolved with technology, everything is striving to become smaller and more efficient. SunLED now offers a portfolio of 110°C High Temperature SMD LEDs. The well-rounded portfolio offers top emitting and side emitting packages in both single and bi-color combinations.
This increase of +25°C over traditional LEDs make it a great series to select for server/datacenters, automotive/EV, medical devices, as well as food & cooking appliances.
The 110°C High Temperature SMD LEDs can be used and designed in just like any traditional LED and does not require any special driver or electrical drive conditions. In fact, many of the parts can act as drop in replacements for existing 0603 LEDs, so this series can be selected to replace existing components to increase the operating temperature.
It should be noted that the forward current derating curve (fig. 1) should be followed to ensure maximum performance and lifespan.
